Zero Rates & Stock Steering
Discussion in 'The Garage' started by bigbluesuburban, Feb 11, 2007.
  1. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    On my 89 3/4 ton 'burb DD, I have a 1" body lift with aluminum pucks and new bushing, 2.5" springs in the front and greasable shackes and bushings. In the rear I have a block that makes the whole truck level. (I will be switching to a shackle flip and a block/shackle combination to level the rig.
    I want to add 1" of lift to the truck to fit 35's. I would like to move the front axle forward the 1.5" also and do this with zero rates. Hopefully I can keep fender trimming to a minimum. My question is this though.
    What is going to happen to my steering when I do this?
    If I am going to loose steering functions... what are my options... OTHER THAN cross-over cause I ain't doing that until I put the D60 under the front.
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    There really are no other practical options. Move the steering box forward. When the axle goes forward, the draglink gets even shorter.
  3. bigbluesuburban
    Feb 8, 2006
    1,362
    Do you think that simply lengthening the drag link would work?
  4. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    You can shorten the stock draglink an inch and a half. You'll be fine.
  5. bigbluesuburban
    Feb 8, 2006
    1,362
    oh yeah, SHORTEN... I was backwards on that... Thanks
