Zero Rates vs. Extended Shackles
Discussion in 'The Garage' started by rcpilot, Dec 29, 2003.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    O.K. have to raise the front of my 76' K5 about 1".. so it's 1" Zero rates or 2" Extended shackles... what have you used and watcha liked or disliked /forums/images/graemlins/thinking.gif
    BTW: I have 4" rancho springs up front and Echobit Flip in the back... The rear sits higher than the front
  2. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Are you talking about the ORD shackles?
    If so I think I would do that to gain height and beef that up. Also would be a good time to change the frame bushings.
    Save the zero rate till you crave more height later /forums/images/graemlins/grin.gif
    How much higher is the rear?
    Are you using stock rear springs?
  3. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Zero Rates
    With extended shackles your pinion angle will be way too much which will require a shim anyways. So the zero rate is easier.
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Zero rates, shackle extended more than an inch can put a lot of leverage on everything (frame, bushings, MY BOLTS). I run 1" extended shackles and 4° steel shims. This gave me about 1" of lift and my pinion is perfect with my 4" BDS springs.
  5. rcpilot
    Feb 22, 2002
    507
    Central Cali
    The 2" shackles I was talking about (Hill's offraod etc)net 1" of lift... The front springs are 4" Ranchos (10 years old though)... I'm liking the zero rates for the fact I don't have shim.. just didn't know if the shackles would give more/better articulation..
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    ZRs.
    j
