Zero rates w/1.5" offset FRONT AND REAR?
Discussion in 'The Garage' started by KRAZIE87K5, Jun 5, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Zero rates w/1.5\" offset FRONT AND REAR?
    Does anyone see a problem with running the ORD Zero rates with 1.5" offsets on both the front and rear axles? Just in case, I have a D60 and a 14BFF, 4.10's, and 36" TSLs. I have to have new shafts made (STILL) after doing the auto-to-manual conversion, so why not take this chance to move the axles out?!!! /forums/images/icons/wink.gif Are there any drawbacks to moving the axles in this manner? Thanks everyone!
    -Dan
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Re: Zero rates w/1.5\" offset FRONT AND REAR?
    I just got the set for my rear today, /forums/images/icons/wink.gif As for the front the ORD site says you may have problems with them in the front and crossover steering. I haven't done either yet so I don't know for sure.
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have a set of ORD's for the rear and a set of 3/4" ones I made for the front. I did not move my front axle because of my driveshaft but hight wize with the 3/4" the drag link clears. My steering arm is only 3/4" so that puts it a little closer to the leaf. I have less then a 1/2" between the leaf and the draglink. PM me if you need more info.
  4. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Measure your front axle 1.5"s in front of where your cross over steering is now and see if you would have problems there?
  5. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I could see problems with the crossover now that that you pointed it out... I wanted it more for the front, to possibly save the front shaft from being resized. I would like them in the rear regardless to make up for droopy butt syndrome! /forums/images/icons/laugh.gif After installing the HD front shackles, the front sits a little higher than the rear now... just enough to where it bothers the hell outta me! /forums/images/icons/wink.gif
    I could use a matching spacer under the steering arm to cure that issue, right?
    -Dan
  6. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    I didn't think about that, ask SW. But you would have to put spacers on both sides to keep them even I would think.
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    A guy on the site Donimator, is running this set-up onhis truck with crossover steering. I dont think he had any issues, you could PM him and ask for sure though.
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Avalanche (sp) makes a spacer for the D60 steering arm. I think the price is $65.
