Zero rates with shim blocks?
Discussion in 'The Garage' started by gmcjimmy88, May 28, 2006.
  1. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    Is anyone running a set of Zero rates plus a set of degree shims. I was just wondering if it would be stable. I see it being bad, like having two sets of lift blocks on the same axle? Or can you order the Zero rates with a 15 degree cut in them? Or is there anyone local to Fayetteville N.C to machine a set for me at a great price. Thanks for any and all help.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Just order them with the correct taper
  3. 74 chev
    74 chev 1/2 ton status
    Sep 30, 2004
    159
    Concord,CA
    i have zero rates and a 15 deg shim and have had no problems but as soon as i can im just gonna swap it all out for 52's.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got the same thing, also swapping to 52s
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I milled 6* into mine and it took forever on the mill. If you can order them pre-cut then do so because it'll cost a lot in shop time to get them done. But considering zeros and degree shims both bolt to the spring pack I can't really see a problem with it.
  6. gmcjimmy88
    Feb 10, 2005
    559
    Cool, I gues I was thinking of them as lift blocks. Did not think they Bolted to the spring pack. What bolts did you use for the bolt?
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Just longer centre bolts. Pro Comp amongst others sell them. Have a word with MuddyTazz though as he may well be able to help you out with shims or degreed zeros. He's a better machinist than me!:D
  8. fright98
    fright98 Registered Member
    Nov 21, 2005
    32
    south of Boston
    whree did you get the 15 drg. shims
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I got a set of 10* zero rates from JKWOffroad. He is a member here.:D I had mine made to be 1" thick at the smallest point and tapered up from there.
    Ira
