zero rates worth it?
Discussion in 'The Garage' started by pismorat, Jun 1, 2003.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I ran across another post where someone suggested 1" zero rates. I have a 4" suspension lift and 33's. I want a bit more height and am planning on running 35 or 36's someday. I don't really want a body lift either. Will I need driveshaft modifications if I get them? /forums/images/graemlins/truck.gif
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Can you say Sawsall????
  3. pismorat
    Oct 29, 2002
    540
    California
    I have a sawsall, and not afriad to use it, will I have driveline problems though? /forums/images/graemlins/truck.gif
  4. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    if 1 more inch of suspension lift will cause driveshaft probs, u prolly already have driveshaft probs at max flex... I run a 4" lift + zero rates front and rear and love em.... of course I have 2 HAD shafts too...
    j
  5. Grim-Reaper
    7,385
    Atlanta
    1 inch Zero rates and a 1 inch bodly lift made all the difference in the world. I was scrubbing all 4 on 32's with Rancho 2.5 inch springs (they are actually 3.75 over stock).
    Shifted the front axle forward one inch and now I don't scrub on 35's at all. I'm cut back less then most.
  6. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Think of it this way, if you run 4" suspension and 1" zero rates, you are only a 3" BL and some custom body work away from fitting 42s. That's experience speaking.
    If you simply go with 1" ZRs, you probably won't have DS problems (being too short), but that really depends on your specific vehicle. And you won't know until you try. If you add these and relocate your axles, you are more likely to have to extend your drivelines. But you can probably find a local shop that will extend your existing DSs for not too much $$.
    I highly recommend them. Sucks when a tire is crammed into a fender preventing you from turning when you really need to. That is first hand personal experience speaking.
