zero rates
Discussion in 'The Garage' started by georgiared84, Oct 30, 2002.
  1. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    Okay, stupid question here. What is meant by zero rate springs? I'm looking into ways to raise mine an inch or two and keep running into that term. Sorry, I'm not to familiar with a lot of suspension terms. All my lift experience comes from finding junked longer springs and heatin and beatin them into a lift. (figured I try to do this one right)
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    From what I understand, and someone correct me if I'm wrong, zero-rate springs are leafs that go in your spring pack, but don't do any supporting with spring action. A 1" zero-rate is a flat leaf, 1" thick..so it lifts your vehicle 1".
    My question is...are zero rates safe for the front? How would it be any different than a block in the front...which is a super no-no?
  3. heavy4x4
    Aug 28, 2002
    3,270
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Zero rate is a fancy name for a block that you bolt to the spring pack. they aren't really a block, since they are bolted to the pack, and they aren't really an add a leaf, since they aren't any longer than the spring perch. Stephen Watson came up with the term "zero rate add-a-leaf" since they bolt to the pack like an add a leaf, but do not increase the spring rate. That's the story I heard, anyways. </font color>
  5. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Zero rates are short lift blocks. They are different because they actually attach to the leaf packs with the center pin. Some of them are drilled for offset pins to move the axle forward or back.
    I dont really see much of a problem with running them in the front because they attach with the center pin and they also arent that tall compared to the width. The main concern with blocks in the front is side force causing them to pop out. This would pretty much be eliminated with the zero rates.
  6. heavy4x4
    Aug 28, 2002
    3,270
    Thanks, that's what I thought...I'm not planning on doing it...only curious.
  7. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    I am running some zero rate springs in the front to move the axle foward one inch and down one inch to help with no sway bar and 35s with 4 inch (now 5).
