ZF axles
Discussion in 'The Garage' started by 1967k10, May 4, 2007.
  1. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    I need some spec's on ZF axles out of a Military Tug. They have 4 wheel steer but I don't know anything else. Any help would be appreciated.
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    They have some insane reduction ratio and are ridiculously heavy. Basically, you don't want 'em.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    Yep.
  4. 1967k10
    Nov 21, 2005
    1,728
    They have 6.72's or lower? Lockers or open? Even if cheap?
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Yeah, they're insanely low geared. Don't quote me on this but I think I was told one time that they're in the 20ish:1 range. Yes, even if cheap, don't bother. A pair of steering rockies would be a way better investment.
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yes, they are known as "geared hub" axles. 21:1 sounds about right from what I recall. Search way on back, they have been discussed numerous times over the last several years...
  7. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    how heavy are the axles? dont the tugs come with some kind of linked suspension?
  8. Speedo
    Speedo 1/2 ton status Premium Member
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    They are called "planetary hubs" have the steering ram built into the housing and have wet brakes. They are better suited to tires in the 60" plus range. They are also expensive to maintain.
    Gus
  9. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Perhaps some do, but the ZF axles under the Chevy-bodied aircraft tugs have the axles solid mounted to the frame.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You're right, my memory fails in old age. Planetarie hubs it is, I knew "geared hubs" didn't sound right, but couldn't think of anything else once it got hung in my head...
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    To make up for my screw up on the name, I dug this out for you. :doah:
  12. Speedo
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    But you ain't old yet, but you're getting prepared for what is to come.
    Gus
  13. 1967k10
    Nov 21, 2005
    1,728
    Well I see you guys point but I hate to see the thing just sit in a junk pile :( . Surely someone could use them for cheap :rolleyes: ,for something.
  14. 1977k5
    May 26, 2003
    9,991
    130
    Got any airplanes to haul around?
