ZR2 Blazer upgrades?
Discussion in '1983-2005 S-Series models' started by TruckNutzDude, Aug 9, 2004.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    So I wheeled the weeeeeeeeee out of my '99 ZR2 tonight. It did fairly well, better than I had expected with a gov loc in the back pushing 31" AT tires. What kind of upgrades are out there for this rig? I've looked at the BDS 5" lift and some 33"s but that would require me to re-gear the axles since it's a dog to begin with. I'm thinking a body lift and some 32's might be good enough... I'd also like to add an exhaust system to compliment the K&N kit I installed. It's a 5-speed with push button 4wd. (What can I do about the push button crapola??? It DID NOT want to shift into 4-LO!!!!!! /forums/images/graemlins/mad.gif) Thanks guys, I know you'll steer me in the right direction ( /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif) /forums/images/graemlins/whistling.gif
  2. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    check out ZR2.com they can steer you in the right direction /forums/images/graemlins/thumb.gif
  3. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I still havent quite figured out the characteristics of the pushbutton on my 03. I usually have to have the clutch pushed in to go into low and the clutch out to go into 4hi. Sometimes if the wheels are turned it wont go in either. /forums/images/graemlins/dunno.gif
  4. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Last Saturday I was out wheeling it and I needed to switch into low range because I was stuck in a washout and didn't have enough power to back out. Low range wouldn't engage and I had to drop the clutch a few times to get out. Stupid me for not engaging low range earlier and stupid low range for letting me down... AGAIN! /forums/images/graemlins/angryfire.gif
  5. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    On my Dad's 98 with auto one has shift on the go for 4 high, to go into 4 Low one must stop put trannie in nuetral and then shift to 4 Low. Could be same apllication for stick shift
  6. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    I've tried the neutral thing a few times but no luck. I'm either going to sell the rig or start swapping in more reliable parts. I already have a 4.10 geared toyota front axle with some 4" springs calling my name /forums/images/graemlins/ignore.gif And a SOA swap for the rear isn't that hard. My only problem is that I'm going to end up losing my speedometer and mess up the computer when I ditch the t-case and start messing with the tone rings that are on all my wheel bearings /forums/images/graemlins/angryfire.gif
    If anyone wants to buy it before I hack it I'll call the bank and see how much I owe on it. You pay off my loan and it's yours. Otherwise the sawzall might be getting it. /forums/images/graemlins/deal.gif
