1984 K10 | My $$$ Eater
So, here's my 1984 K10. It was my brother's truck until he passed away in 1991. It needs a lot of TLC. Plans are to run a 5.3/4L60e/208. (Later plans involve upgrading to 14bff as well as upgrading my front Corp. 10 bolt to 3/4 ton.) It has 3.08 gears, so that'll have to change too... Right now, I get about 9 miles to the gallon. This's will be my daily driver.
I intend to run with the DBW.
Yep, I'm still looking for a way to run that 208 with the 4L60e. I'd like to find an adapter that will make this work. I'll obviously need someway to get the VSS in order too.
Currently running on a worn 350/700R4/208. 4" Lift with 33/12.50's
For now, I need to get it street legal. Been sitting out in a field in East Texas for the last 5 years... (12 too many deployments)
So, it seems that brakes are first in the order... That'll be what I tackle while I'm waiting on the government to come out of this shutdown.
K10
Custom Deluxe
350
700R4
4 inch Rough Country front springs; 4 inch blocks; Rancho shocks
Corporate 10 bolts
American Racing 15x8
33x12.50x15
Silver
More from treborjm87
Found this on CL last week. I had to have it! After seeing @Larry build the Polar Bear Suburban, I have been looking for a factory equipped SM465 Suburban. This is a 3/4 Ton (from the factory... (I saw the GM build (option?) sheet on the driver side front fender) with a semi floating axle out back. This isn’t nearly as nice of a start up rig as @Larry Polar a bear, but the bones are... well, they are there. Under the hood is a less than 10,000 mile Jeg’s crate 350 motor...
treborjm87
806
