I've had the Blazer about a month,its all original with little rust and only a few dents. I've fixed a turn signal issue, which ended up to be the signal switch in the column. I also had a stuck front caliper that tried to pull me in the ditch every time I braked. The rear wheel cylinders were replaced since they were leaking every where.
There's a hundred little things that need to be fixed after nearly 30 years of neglect. My plan is to get all the safety and mechanical issues fixed so it's easier to drive. Which will give me time to think about which direction to take this project.
