1989 Diesel Jimmy. What do we have here hmmmm
So I bought this Jimmy to have as my daily driver.
Couple of things I need to address very quickly. The transmission is going out that is currently being addressed I will be getting my trans on Thursday from Mt. Home.
Need to fix the windshield wipers the back window (it worked several times before not working), lube up the power windows, do a complete fluid change on the diffs rad. engine etc. Double check the rear and front wheel bearings. Just go through everything and double check.
This is going to be a daily driver not touching it until it needs replaces kind of build.
It already has a 6" lift and 35s 10 bolts front and rear, have no idea what gearing
My first trip home with it got 19 mpg so I am pretty happy with that
Anyway here are some pics
More from blazinzuk
blazinzuk
1,252
2wd big block burb tow rig
blazinzuk
5.00 star(s) 1 ratings
2,337
Reviews
introducing horton That is the start of the exocage I am going to build over the next couple of weeks. The fact that I broke the back window has slowed progress until I could get the window replaced hopefully tommorow. I will post up with future up dates that include changing the leaf springs in the front finishing the cage, one linking the rear, moving the gas tank (again!) Specs are as follows 60 14b both with detroits 4.56 gears 56" springs in the front 63s in the rear stock tbi...
blazinzuk
1,348
