1991 Chevy Crew Cab "R" / "V" Conversion
I have been a lurker here for a while and finally made enough progress with my project to start a build thread. Truck started out a 1991 Chevy R3500 Crew Cab with a TBI350 and a 4l80e trans. This truck is not going to be a "trail rig", it may see some trails but im not building it for flex etc. The end goals are a Cummins swap with a NV4500 & NP205 with 37-40" tires that can still pull a trailer when needed.
Nov. 2008ish - When i brought it home
Dec. 2008ish - Then i cleaned out the cab and installed some 33X12.5X16.5 tires, installed seats from a 2004 Extended cab Chevy and removed the ugly grill guard.
Found some 37X12.5X16.5 Military Good Years GSA and thought "Why Not" - Feb. 2009ish
Sept. 2009ish - Swapped in a Reman 350 with Serp pulley setup
Oct. 2012ish - It sat that way for a while until I finally got the rear seatbelts installed
July 2013ish - Started getting parts together for the 4wd swap
Installed some 64" rear springs
Sept. 2013 - Started moving brackets and installing my stock Superduty leaf springs up front.
Jan. 2014 -Pulled the drivetrain from the 2wd and set it in the 4wd frame then swapped the cab and cut up the 2wd frame.
And that brings it up to date, currently looking for a 4wd NV4500 so i can swap it in along with my NP205 and make it a real 4wd. Thanks for looking.
mckustomfab
1,938
4
