This is my condensed build thread. I just copy/pasted/edited from my local forum.
DIY SAS kit.
DIY shackle flip.
WFO pitman.
Dana 60/14bolt with 4.56's
I will run the 36" irocs for now.
PSD 241 with VSS and 32 spline input.
Rig is a 1995 2500 burb. TBI 350/4l80e.
No oxy+torsion bars= the suck.
7 bolts hold on EACH front spring hangar.
IFS parts.
Got one spring. Working on the other side. I have to cut more of the Y pipe for the new hangar to clear. Frame is as cleaned up as I care for it to be. Hopefully tomorrow I can get some brake lines and turn it around, then tart on the shackle flip. It's VERY obvious these frames are MUCH stronger then square body frames.
After the axles are in I have to pull the case and swap the 32 spline input into my psd 241. Gotta fix the floor. It's rusted, but not out by the rockers. It's weird. I'm going to pull the interior out and do it once. Replace what needs replaced the probably Rustoliem it. I understand the bed liner option, but I want sound deadening and some insulation wherever it helps.
The 1/2 ton burbs have a different front spring hangar so it sits lower. The *** end of thing was high from the start so hopefully I get enough lift out front.
