69 LSK5
  • 1st Gen LQ9 2006 Vortec Max, 4L65E or 4L80E/NP205, 14 bolt 373:1 G80 SF 6 lug rear, original D44 upgraded using Yukon Gear components , Reid Racing Knuckles, Sky Manufacturing Hi-steer, hydraulic assist steering (maybe PSC)?, hydro-boost 4 wheel disk brakes, 4 new 52” new stock springs with ORD flip kit & DIY4X 1ST Gen B52 Kit, 87 suburban Fuel tank with Walbro upgraded in-tank pump.
    1969
    TBD
    TBD
    Factory Options:
    Standard
    2006 LQ9 taken from Silverado Vortec Max
    4L65E or 4L80E
    Original NP205
    Sky Manufacturing Hi-Seer Reid Racing knuckles
    4 New stock 52” springs with Diy4X first gen B52 kit
    373:1 14 bolt SF G80 six lug rear, D44 with Yukon Gear Chrome Moly axle upgrades
    TBD but likely factory 15” Rallies or 18” to 20” look a like
    33”
    Red/white classic scheme using upper/lower moldings
  • As with any build, I have had a general idea of what I was going to do. I had the original TH350 & NP205 & a 350 crate engine with only 15K miles on it but the 6.0L came with 81K miles & a matched 2WD 4L65E for a deal I couldn't refuse so the 350 is coming out. I tried to sell the 4L65E so I could get a 4WD trans but no luck so I'm still thinking about what I am going to do about it. I will have to do some machine work I changes to the 205 to make a 4L80E work with it, I have a 700R4 from a 91 K5 that would bolt right up but the LS is a DBW so maybe I'll just send in the 4L65E in and have the rear shaft switched to 4WD...5 transmissions in the shop & not one really does it for the Blazer. I have the gearvenders over/under but the wheel base may be to short to use in in this one.
nvrenuf likes this.
