82 K20 CREW "WONTON"
I've finally been convinced to make a build thread. I picked up this truck in January from a friend.
The story behind the truck is a few too many beers, a tree and a big mud hole. It got stuck in a spillway for a pond. Then it rained and the truck sat in 3 feet of water for 2 months.
It was exactly what I wanted and knowing that I would go through everything anyways it was a good buy.
As I bought it.
82 K20 crew cab
350 swap (started life as a diesel)
Nv4500
Dana 60 front
4in spring lift
The plan for it was to build a fun daily/crawler. With it being under water the engine had bent a rod and the nv4500 case had cracked from freezing while full of water.
I'll start with the drive train. So far I swapped in a junkyard 5.3 vortec. Gave it a fresh coat of paint, ls swap engine mount adapters with factory mounts. Lsa exhaust manifolds. Drilled the water pump for the steam vent and mechanical temp sensor. I used an 06 6.0 flywheel and drilled the standard nv4500 clutch for metric bolts.
As for the transmission. The case was cracked and after much searching I found a new oem case. I also decided to replace the mainshaft, 5th gear and input bearing retainer for good measure.
I'll post more tomorrow.
Chinahands
1,515
3
