83K5_blazer (ORD 4” lift has begun!!!)
  • Here is a build guide to help anyone out:
    Start of rust repair
    Hard top repair/ restoration
    ORD 4” lift (front end)
    I'm calling this the "Resnecked Resto" due to the condition this was in when I got it. Hacked up wiring throughout, pieced together seats from three different trucks. Rocker and floor rust and it had been primed over primer several times. This will be converted to a full vert truck using a 74 top and header frame.
    1983
    K5 - Blazer
    YE9 Silverado
    Factory Options:
    Silverado - A/C
    Currently:
    350 c.i. - 14010207 block
    Holley Street Warrior 4160 600cfm Carb
    Edelbrock Performer EPS 2701 Intake
    Summit HEI Blueprinted Distributor
    Taylor Street Thunder 8mm wires
    TH700-R4
    Factory
    4” Tuff Country front springs, ORD HD front shackles, ORD FUSH kit, ORD swaybar disconnect kit, Bilstein 5125’s.
    Factory 10 bolt 6 lug
    American Racing Outlaw I 15" x 10”
    Mickey Thompson Deegan 38 MT’s - 33x12.5x15
    Factory - Midnight blue/ white top
    Currently a mix of primer and Vvivid vinyl wrap
