Ok, first things first, this thread will be a slow starter. I do not spend alot of time on the computer outside of work, and most of my pictures are at home or on camaras (that i do not have access to at work). But I have a few here to get started.
Here we go,
I found this truck on C-list for $600 obo. Said it ran and drove in 1st gear, but no higher gears. Went and picked it up on a friday night after work for $300. Got the truck home and started to dig in.
Here we go,
- 1986
- GMC
- Jimmy
- Sierra
- Mostly stripped. Still has factory dash. 92-98 K5 buckets and factory rear bench.
- A/C truck, but compressor has been removed.
- 8.1 Vortec Big Block from a 2001 Silverado 2500HD
- Built TH700. Corvette servo. Extra clutch discs. Mild shift kit. B&M cable shifter.
- Stock NP208
- Full hydro using a Trailgear 8" single ended ram, mounted to a high-steer tierod with heim joints.
- 4" Superlift front springs with factory shackles and poly bushings/greasable bolts. 4" shackle flip rear with factory 52" springs. 12" travel Fox Shox.
- Dodge Dana 60 front with welded 4.56 gears and Diy4x powder coated diff cover. 14BFF rear with Detroit locker and 4.56 gears. Rear disc swap Barnes4wd diff cover and pinion guard.
- Non-recentered 24bolt H1's.
- 39.5x15r16.5 TSL's
- Keystone Spray-on bedliner
