1st I'd like to say I'm king of procrastonation and this has been too long coming (about 3 yrs).I finally finished my rolling chassis enough to put the body on it so Slamchops helped me get it done last Sat. I had beem dreading this part so hopefully, now that the worst is over things will move a little faster now.
Final assembly specs :
*454 carb'd, steel crank, 9.4 comp, 7/16 rods, roller cam, 781 heads, Sanderson shorty headers & single exhaust
*4spd w/ ORD 32 spline conversion, hydro clutch
*ORD Doubler twin sticked w/ 1410's
*Jana76 (D60 w/ 70 gears) w/ Power Lock, 5.86's, 35 spline outers, Spicer locking hubs
*D70HD w/ spool, 5.86's, narrowed to srw width, disc brakes using front D60 rotors & calipers
*Front lift: 2.5" lift 52" springs
*Rear Lift: stock 56's, Zero Rates, ORD 2.5" shackle flip
*Weld D7 16.5x12 wheels & wheels w/ 43" SX's
*8k Warn winch in Diy4x bumper center / Diy4x rear bumper
*Full roll cage
Anyway I'm bored at work so here are some pics -
The next step will be to clean / install the tank and finish the fuel & brake plumbing.
91 K5 -Procrastination Build - Full top conversion complete
K5 Blazer | Jimmy build created by nvrenuf, Sep 25, 2007
