FAT BASTARD 81 C30 Service Truck
4x4 conversion, clean it up and outfit it for work.
So, I picked this truck up in a trade deal plans were to put the bed on Smokey and use the cab on my single cab K30 project.
But after doing some measuring of the bed , it won't work because this is a Cab Chassis truck so the cab to axle distance is not the same as a pickup.
So after going over the truck I decided it would be better to just swap in a set of CUCV axles in and convert it to single wheel.
I will run the Toyo MT 37-13.50 17 which is a E rated tire good for 4300 lbs per tire (about 700 more then the e-rated stock tires in dual configuration )
454 will just get a good tuneup and possibly a new intake and Valve Covers . And definitely an upgraded alternator.
Front will get an old warn winch bumper with 17k smittybilt .
Shoe String budget here, so everything has to come from my current parts pile or from trading/selling parts.
1981
C30
Scottsdale
Brown
A/C , Cruise ,Intemittent wipers
454
SM465
NP205
Crossover with hydro assist
Leafs with bags
14-bolt/Dana 60 with 4.56 gears Detroit Rear limited slip front
17"
37-13.50/17 Toyo MT
Rustoleum
More from yellowK20
yellowK20
1,086
Modern-ish drivetrain and creature comforts
yellowK20
1,122
Picked this up today for cheap It's a 84 K20 burb 6.2 Th400 NP208 Dana 60 5.13 detroit locker 35 spline stubs Hy-steer 14-bolt 5.13 detroit locker DIY4X disc brakes 8" fronts springs 4" 56" rear springs Homebrew shackle flip 2" bodylift Mile marker winch Ord weld in brace Ord Bolt in brace lots of rust :doah:
yellowK20
979
I guess I dont have a Build thread for this thing yet so hear goes. I bought this truck from a dealers lot with a "Bad engine" for 1000.00 it had a set of 33" BFG all terrains in the back when I picked it up which I sold that night on Craigslist for 600.00 The truck sat for about a year with out having anything done to it, then one day I grabbed some batteries from Wal-mart and tossed them in and gave it a try Starter was ****ed bendix was trashed!! I left for New Mexico that...
yellowK20
1,176
I bought this truck for my awesome girlfriend Patty , its a '84 C-10 on a '78 K20 frame with '75 K20 axles. it has a Full roller 12.5 to 1 396 with ported LS5 454 heads a TH400 with 3200 stall and a NP208. It has 4" suspension lift and 3"BL Plans are : Body and Paint ( with sweet lund visor!!!) 40 Blazer tank Fuel Injection ( Fast or Holley pro-jection) New Interior ( changed from red to black) Dana 60 with ARB and 5.13's ( from my buggy project) with 35 spline outers 14...
yellowK20
1,071
