This truck has been in our family for awhile, and very abused its entire life. Has been only used as hunting rig for the last 25 years or more and not driven on the roads. 17 in our families possession alone.
My Stepmom wanted to sell it, and it was at a reasonable price so i sold my tacoma hunting rig and bought this and a bunch of parts a year or more ago.
From a badly cracked frame barely holding on, wheels held on by only a few lug nuts that weren't stripped, dozens of jerry rig fixes, hack jobs, wrecks, and cheap body work to fix that, it is finally getting some Much needed TLC.
Some of these yes were even my doing unfortunately. But when your in the middle of nowhere you do what you have to do to fix it and then just keep running it.
- 1986
- Blazer
maroon/ faded red
Flooring everywhere was professionally rhinolined Red at one point. One positive.
305
ORD engine Xmember and comp motor mounts
700r4
Energy suspension mount
- NP 208 w/ SYE
Dueling Design frame plates, both sides.
ORD steering box frame repair and box brace
79’ Pump for SAE fittings
PSC box
Borgeson Shaft
ORD Crossover W/ HighSteer
4” total lift
ORD 52” custom Rear w/ Extreme Shackles
Bilstien 5125’s all 4 corners specd from ORD
ORD custom fronts w/ new hanger and FUSH
ORD Front Sway Bar w/ Quick Disconnects, W/
Energy suspension bushings
2004 Chevy 2500 14bFF rear: 5.13 Detroit full rebuilt 1350
1979 Chevy D44 front: 5.13 TruTrac fairly fresh rebuild w HD shafts and jts. Reid knuckles.
- Slab ATX 17” Beadlocks
- 38” X 13.5” X 17”
- spray can rhinolining thats flaking off.
