I don't know yet
2wd big block burb tow rig
I guess several people know I am getting a 2wd 1990 3/4 burb. @Z71paramedic has been key in making this happen thank you sir.
As soon as I sell my 6.2 4x4 I'm off to Seattle to pick this gem up
Suburban
Yes
Red!
Everything cool
454
Th400
Nope
Yes
Not low enough
14b
80s aluminum awesomeness
Ish
90s faded and chipping
More from blazinzuk
blazinzuk
1,352
So I bought this Jimmy to have as my daily driver. Couple of things I need to address very quickly. The transmission is going out that is currently being addressed I will be getting my trans on Thursday from Mt. Home. Need to fix the windshield wipers the back window (it worked several times before not working), lube up the power windows, do a complete fluid change on the diffs rad. engine etc. Double check the rear and front wheel bearings. Just go through everything and double check...
blazinzuk
5.00 star(s) 1 ratings
2,340
Reviews
introducing horton That is the start of the exocage I am going to build over the next couple of weeks. The fact that I broke the back window has slowed progress until I could get the window replaced hopefully tommorow. I will post up with future up dates that include changing the leaf springs in the front finishing the cage, one linking the rear, moving the gas tank (again!) Specs are as follows 60 14b both with detroits 4.56 gears 56" springs in the front 63s in the rear stock tbi...
blazinzuk
1,256
4
More in Suburban
