it’s Not A Bronco!
My 72 blazer that I’ve put way to much time and money into
This is my 72 blazer (as it sits today) I got when I was 19. It’s crazy looking back on it because when I bought it originally I couldn’t tell you what a distributor cap or a tie rod was. All I knew was that I wanted an old Chevy blazer
It was pretty stock (looking) when it was new to me. Didn’t know it till I got it home but the rear floors are pretty damn Rusty and there’s a bit of rust on the driver side floor plan
the top was a wreck so I ditched it after a few months
Changed the engine and trans
I also wanted a roof rack but didn’t want to get rid of the soft top so I built my own thing for a roof rack minus the tubing bending and welding cause I’m not that skilled
You might notice I went down to 33 inch tires rather than the 35’s that came with it, I didn’t realize it at the time but I had broken rear leaf springs and it made the suspension sag enough to where the 35s rubbed badly
Got fuel injection in late 2016 but I changed it recently, just cause it wouldn’t cooperate with me at any point and it got worse in the last couple months
After getting rid of the rear blocks and changing the front and rear spring packs I went back up to 35’s and had no rubbing afterwards, This was late last year I took this picture up on inspiration point only a few things have changed since the time of this shot
Took it to a four wheel parts event and ran into kgblazerfive and Twinkie and he made me sign up here LOL. But I’m glad I did!
Haven’t done much with it after that point except build a winch bumper (not finished yet).
And that’s about it other than changing the engine crossmember to the DIY4X cross member and ditching the fi-tech for a holley truck Avenger.
More things to come including probably a 14 bolt semi float swap. And random other things along the way
P.S This is what I call it the not a bronco blazer, it seems like everyone I’ve ever met thinks it’s a bronco
1972
Blazer
Cst
A hodgepodge of new, old, and wrong
None
Rebuilt 350
Turbo 350
Np205
ORD HD tie rod Raised Arm/stock
4” rough country springs with zero rates up front
D44 12 bolt
15x8 rallies
35x12.50 r15 grabber X3’s
Grey
More from Not A Bronco
Found a deal on a 79 jimmy that was sitting in a repo lot. Looks to have been restored at some point, but has some bad gaps and body damage from bondo that needs addressing and a few other things. But I’m stoked, never thought I’d own one this clean!
Not A Bronco
761
1994 c3500 6.5 Diesel 4L80e, plans include a flatbed, re-paint and solid axle swap 2-4" lift with HD D44 and a 205 t-case.. and eventually a cummins swap
Not A Bronco
2,258
