Potent Rodent Revival
Average User Rating:
5/5,
  • Last time she was running in Moab...
    New Engine Specs:
    SBC 406ci
    Dart Block
    Forged Callies Crank
    Forged Callies Rods
    Forged JE Pistons
    AFR 210cc Eliminator Alum heads
    ARP Pro Series head studs
    Felpro MLS head gaskets
    ARP Main / Rod studs
    Comp 280xfi Roller Cam
    Comp Pro Magnum lifters
    Comp Pro Magnum rockers
    Billet Timing Chain with Cloyes cover
    Pro Comp EFI Intake
    Corvette 90mm throttle body
    PP Fuel Rails
    200lb FIC injectors
    Holley TB Elbow
    Haltech 2500 Elite ECU-
    Holley 60-2 Crank Trigger:
    Factory GM LQ9 truck coils.
    MSD oil pump drive (no more distributor)
    Only Flexplate I found that works with an old SBC and the 4L80E trans
    PRW Xtreme Duty SFI-Rated Steel Flexplate Small Block Chevy
    PRW 1835030
    Jegs Part Number: 228-1835030
    New ORD Crossmember Done
    Built 4L80 manual valve body ready to go in
    Engine going in. Excuse the years of dust...
    NP-205, 32 spline with 1350 CV flanges.
    4L80 and NP 205 installed. Billet PTO cover added with new fill hole.
    Also adding-
    JB Fab NP205 Cable Shifter
    TTF NP205 Clocking Ring
    Engine installed
    Getting close! Had to go different direction on EFI setup and ECU.
    Ported Hydroboost and new Wilwood master installed
    4L80 gate shifter and JB Fab twin stick shifter installed in newer F150 center console.
    New headlights installed
    1987
    Built 406ci, MPFI, Haltech
    NP205
    Crossover, AGR Ram assist
    BDS front, Tough Country rear
    Dana 60, 14 bolt
    16.5x9.75 (old style)
    38" Parnelli Jones
    Custom gun metal, Ford Blue/Purple
    Engine Specs
    SBC 406ci
    Dart Block
    Forged Callies Rods
    Forged JE Pistons
    ARP Pro head studs
    Edelbrock Pro-Flo 4 MPFI
    Dana 60 with ARB
    14 bolt with Detroit
    4.88 gears
    Trans/Tcase
    4L80 manual valve body, NP 205
    6" BDS front, 2" Tough Country with ORD flip rear
    9012 shocks
    Misc:
    High Angle CV Drive Shafts with long slip
    JB Fab Twin stick shifter
    TTF clocking ring
    AGR Ram Steering
    Custom drag link, tie rod
    Kayline Top
Recent Build Reviews
  1. K5Devil
  2. CK5
    5/5,
    "Because Turbos!"
  3. heavy iron
    5/5,
    "that's going to be a power house ."
  4. 76zimmer
    5/5,
    "eagerly awaiting the fire!"
    always cool to see a resurrected K5, especially with a new powerplant!
    Shawn likes this.
  5. Greg72
    5/5,
    "A Classic CK5 Build"
    Glad to see you back Shawn!!
    BB2018...?
    -G
    Shawn likes this.
    1. Shawn
      Thanks! I might make it out this time.
