Offroad Potent Rodent
New built engine, EFI, 4L80 transmission, t-case, brakes, hydroboost, tires/wheels and more!
Engine Specs:
SBC 406ci
Dart Block
Forged Callies Crank
Forged Callies Rods
Forged JE Pistons
AFR 210cc Eliminator Alum heads
ARP Pro Series head studs
Felpro MLS head gaskets
ARP Main / Rod studs
Comp 280xfi Roller Cam
Comp Pro Magnum lifters
Comp Pro Magnum 1.6 rockers
Billet Timing Chain with Cloyes cover
Edelbrock Pro-Flo4
Only Flexplate I found that works with an old SBC and the 4L80E trans
PRW Xtreme Duty SFI-Rated Steel Flexplate Small Block Chevy
PRW 1835030
Jegs Part Number: 228-1835030
New ORD Crossmember Done
Built 4L80 manual valve body ready to go in
Engine going in. Excuse the years of dust...
NP-205, 32 spline with 1350 CV flanges.
4L80 and NP 205 installed. Billet PTO cover added with new fill hole.
Also adding-
JB Fab NP205 Cable Shifter
TTF NP205 Clocking Ring
Engine installed
Getting close! Had to go different direction on EFI setup and ECU.
Ported Hydroboost and new Wilwood master installed
4L80 gate shifter and JB Fab twin stick shifter installed in newer F150 center console.
New headlights installed
1987
Mostly stock, Dakota Digital gauges, F150 console.
Built 406ci, AFR heads, Comp Roller Cam, Edelbrock ProFlo 4
NP205, JB Fab twinstick
Crossover, AGR Ram assist
BDS front, Tough Country rear (ORD springs soon)
Dana 60 with ARB, 14 bolt with Detroit
17x9 KMC Grenade Crawler Machined
40x13.5x17 Nitto Trail Grapplers
Custom gun metal, Ford Blue/Purple
Engine Specs
SBC 406ci
Dart Block
Forged Callies Rods
Forged JE Pistons
ARP Pro head studs
Comp Pro Magnum rockers
Edelbrock Pro-Flo 4 MPFI
Dana 60 with ARB
4.88 gears
Trans/Tcase
4L80 manual valve body, NP 205
6" BDS front, 2" Tough Country with ORD flip rear
Bilstein Shocks
Misc:
High Angle CV Drive Shafts with long slip
JB Fab Twin stick shifter
F150 Console
250 amp Wrangler Alternator
TTF clocking ring
AGR Ram Steering
Custom drag link, tie rod
Softopper Top
More from Shawn
Shawn
Updated
369
89 Blazer Restoration
Shawn
Updated
588
Restoring a 79 Blazer with some mild mods
Shawn
534
1923 Willys T-bucket with too much power and zero safety in mind
Shawn
Updated
4,271
Updating and improving a military M1008
Restomod 69' Camaro
Shawn
5.00 star(s) 4 ratings
3,184
Reviews
4
Found a good deal on a 69 Camaro with a really nice body and paint. Engine is mostly stock but that will soon be changing. Dressed up the engine a little. Still slow... Added some new wheels/tires. 17x9.5 rear, 17x8.5 front. Re-worked the grill and added front spoiler... Next upgrade...
Shawn
12,128
10
Reviews
5
5.00 star(s) 6 ratings
