Shady's Crew cab short bed project (SOLD)
Alright, I've had quite a few sqare bodies since I joined this group. As dueling says "I MAY have a car buying problem:whistle:" But I finally have what I've been hunting and shooting for. I picked up this CCSB last night. It needs a lot to be a good wheeler but its the body/frame/ suspension that sold me. Not to mention a little stupidity and inattentiveness. Its got a 350/350/208/10b/10b:doah: drive train. I didnt notice that it was a 1/2 ton driveline till I was half way home. But this will drive me around till I can find what I want for a drivetrain.
After fixing the steering, speedo, idle, brakes, leaks, and a couple gauges it should be a good driver:rolleyes::haha: It drove me the 3+ hours home as is with only a few tense moments, and one phone call to a fellow ck5'er. Thanks AJMBLAZER:waytogo:
More from shady
shady
798
Little lower, little cooler, bigger sounds.
shady
1,287
81 CC short bed conversion
shady
1,740
86 K20. As is now it has a 454 bored .40 with a lunati cam one step above RV. Sm465, 208, D60, ff14b. 3.73's 6" all spring lift, no idea of brand. Currently running 37" bias plys.
shady
1,331
Alright heres the start of my 88 grand luxe burb rebuild. I'm a pic whore so there will be alot of them. As you can see its a great base to start with. this will be a DD/towrig. Main plans are (in basic order) Repair all fire damage and clean up the engine compartment along the way. Remove the fiberglass runners and fix any rust that has started ANYWHERE I can find it. Then get it all coated n protected cause I'm gonna have this one for a long time. Once I see how she rides I'll decide...
shady
1,390
Well, I thought I'd go ahead and start this one but it may take a while between updates. Some how I lost the pics of before it went in the garage. Space is tight so bear with me on pic quality. This is what I've compiled so far.
shady
1,172
