Snafu buildup
This will be my attempt at bulletproofing my K5
So this is going to be my build up of my K5. Having a build thread should entice me to keep moving forward.
My plans are to remove the conestoga rough country lift and go down to a 4" shackle flip and 4” springs up front.
Also going to keep a watch at the local u pulls for some 1 tons.
Have a trip planned for this sunday to go and extract a 5.3 from an 03 avalanche, and maybe a 14 bolt from one of the 3 3500s that are sitting around...
Feel free to ask anything.
My questions for the group, 4l60e or 4l80e? Keep the np208 for its low range or swap to an np205 so that i would be able to go with a double cardan rear axle instead of slip yoke?
Pics are as it sits
1987
Blazer
Missing most of it
5.7
700r4
Np208
Kinda sketchy
Rough country 6”
Stock 10 bolts with 4.56gears and open diffs
Stock¿
Bfg mud t/a
Missing most, unless you count primer as paint
Summit racing 600 cfm carb
6” lift
35 ” mud tires
Deleted interior
Craptastic long tubes with a hole in a primary tube
Stephen Carter
1,189
