I will tell you, and I have said this many times, I recommend using the original system in the dash, adapt a compressor if needed.
I made the mistake of putting Vintage Air in my '70 K10 and got tired of the noise from the fan, and especially the lack of heat. It COULD NOT keep the windows from fogging in the winter, or during a rainstorm in the summer. It made it a nice weather truck because the only thing that it did well was A/C.
I pulled it out and found factory housings to go back in. Now I have lots of heat with less noise.
I know that many doubt my view, but I had that truck in temperatures from the single digits to over 100*. I used the system for 4 years before I pulled it, tried everything that was recommended for keeping the windows clear. It has a adjustable thermostat for winter use, no help. The fact that it was recirculate only was the biggest problem there.
If you only use the truck on nice sunny days, no problem.
As far as cost, I believe that it is about the same either way, but I want something that works year round. Having the windows fog over in a summer rain storm was a royal pain. Ice on the inside of the windows was annoying.
I am using 134A in the stock system on my '90 Jimmy and it works well. I have been around a '78 using 134A, no problems with it, except a plugged condenser after all of the decades of use.
