‘96 Bayliner Capri 2050 SS 40th Anniversary
Discussion in 'Other Rides' started by GWeakland620, May 17, 2020.
  1. Truckman4life
    Truckman4life 3/4 Ton Status Premium Member
    Feb 17, 2010
    4,795
    5,255
    Cleveland, UT
    Build(s):
    4
    I wouldn't mind having a boat like this but I've got no time and definitely no money for added hobbies on top of the crap I got going already.
  2. GWeakland620
    GWeakland620 THE CK5 Crayon Eater Premium Member GMOTM Winner
    Sep 15, 2010
    14,771
    13,814
    Toe-peek-ugh, KS
    Build(s):
    5
    Same here lol.
    I have time now since I’m laid off, but normally I don’t. So I decided to use this time to get to a pint to where I can get this boat going.
    Weird Beard and Truckman4life like this.
  3. JoshHefnerX
    JoshHefnerX 1/2 ton status Premium Member
    Jan 7, 2015
    4,185
    2,798
    Glendale, AZ
    Build(s):
    I'm excited to see what the interior turns out like.
    GWeakland620 likes this.
  4. GWeakland620
    Sep 15, 2010
    14,771
    13,814
    Toe-peek-ugh, KS
    Build(s):
    5
    Thanks me too!
    Started the day off with a ton of rain, so we ran errands until about 10:30.
    I then suited up with respirator, paint suit, and face shield to start at the front of the boat.
    After that I moved to the main deck area, only to get sick of all the rotted wood all over the place, so I decided to clean up everything to see where I was.
    Last cut of the day with the grinder was lackadaisical to say the least, and it got away from me. Got lucky, but ruined my suit.
    Scribbles and tRustyK5 like this.
  5. JoshHefnerX
    Jan 7, 2015
    4,185
    2,798
    Glendale, AZ
    Build(s):
    Was all of that ply un-treated? May be expensive but as you replace may consider putting a layer or 2 of fg matting and some epoxy resin to seal it all up nice. keep the rot at bay.
  6. GWeakland620
    Sep 15, 2010
    14,771
    13,814
    Toe-peek-ugh, KS
    Build(s):
    5
    We are replacing with marine grade plywood, the glassing over it and resin. Should keep for a long time after that.
    Went back out and pulled some more that I had already cut.
    JoshHefnerX, ZooMad75 and Scribbles like this.
  7. GWeakland620
    Sep 15, 2010
    14,771
    13,814
    Toe-peek-ugh, KS
    Build(s):
    5
    What do you do when you want to go boating, but your boat doesn’t have a floor? Why, you grab your dad’s boat that he’s not using.
    JoshHefnerX and Capt Ron like this.
  8. fourxpete
    fourxpete Registered Member Premium Member
    Jan 3, 2012
    92
    28
    clarksville, tennesee
    check out advantec plywood it has a 50 year guarantee lot cheaper than marine grade
    JoshHefnerX and GWeakland620 like this.
  9. GWeakland620
    Sep 15, 2010
    14,771
    13,814
    Toe-peek-ugh, KS
    Build(s):
    5
    Wife was off today so I got a break from daddy duties.
    Got to the shop pretty early and started digging in. Still had quite a bit to cut out so I could start laying new wood down.
    Picked this up on sale for $50. It was recommended by guy on the Facebook Bayliner group. Made a huge difference cutting, and had hardly any dust.
    Tore the sundeck apart and finished cleaning up the rear.
    Then got the first sheet down for the new floor. Small step, but big victory so far.
    Smokinthehippies likes this.
  10. ktmoutfront
    ktmoutfront GnomeWorks LLC Premium Member GMOTM Winner
    Feb 20, 2007
    19,048
    23,139
    Somewhere being famous.
    Build(s):
    4
    Nice progress. Ans I use my multi saw weekly.
  11. JoshHefnerX
    Jan 7, 2015
    4,185
    2,798
    Glendale, AZ
    Build(s):
    yeah picked up a saw like that a couple of years ago. use the hell out of it. a lot more than I thought I would.
  12. GWeakland620
    Sep 15, 2010
    14,771
    13,814
    Toe-peek-ugh, KS
    Build(s):
    5
    Yeah I have a feeling I’ll be using it a lot more around the house.
  13. GWeakland620
    Sep 15, 2010
    14,771
    13,814
    Toe-peek-ugh, KS
    Build(s):
    5
    Also, carbide bits are a must for extended uses.
  14. GWeakland620
    Sep 15, 2010
    14,771
    13,814
    Toe-peek-ugh, KS
    Build(s):
    5
    With me returning to daddy duties today, I decided to head to the shop early this morning and get a couple hours of work in before the wife had to be to work at 8am.
    Got the throttle and side panel removed. Then tore out the driver’s seat box that was rotten. The finished removing the old flooring from the same side.
    Everything is cleaned up, and ready for new floor up to the helm.
    I’ll be heading back to the shop with the boys later, for as long as I can take the constant questions of “what are you doing? What is that? Why are you doing that?”
    AJMBLAZER, ktmoutfront and Capt Ron like this.
  15. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    23,551
    1,167
    Paducah, KY
    My problem is sooner or later the two year old grabs something dangerous and starts giggling maniacally and running around in circles with it.
    I spend more time retrieving tools and dealing with fits than I do fixing/building.
  16. ktmoutfront
    Feb 20, 2007
    19,048
    23,139
    Build(s):
    4
    I was at the auto parts store one day. Before cell phones. Manager answers the phone, looks at me and says, "it's for you". Neighbor tells me to head to the hospital. 3 year old daughter climbed the shelves to get the drink I was hiding from her. Big gulp cup full of gas to clean the parts. Yep, she drank it. Wife was out there with her, but was chatting with the neighbor.
    AJMBLAZER likes this.
  17. GWeakland620
    Sep 15, 2010
    14,771
    13,814
    Toe-peek-ugh, KS
    Build(s):
    5
    Wow!!! That could have been a very bad deal!
  18. ktmoutfront
    Feb 20, 2007
    19,048
    23,139
    Build(s):
    4
    She is lucky to be alive. I have a list of her failures like that.
  19. imiceman44
    imiceman44 Hoarder extraordinaire Premium Member
    Aug 5, 2002
    21,294
    5,146
    Lincoln, CA
    Build(s):
    5
    That's what happens with me.
    2.5 and 4.
    I thought once my daughter got older and more mature I would get more garage time but then we got the boys and she started wanting other things.
    I just try to do minimum necessary but I am working on her to start helping watching the kids so her mom and I can get things done
    AJMBLAZER and GWeakland620 like this.
  20. GWeakland620
    Sep 15, 2010
    14,771
    13,814
    Toe-peek-ugh, KS
    Build(s):
    5
    Afternoon update.
    Second piece in. Only floor part left is the bow. Then box the rear bench and glass.
    ktmoutfront likes this.
