I ran out of .035 in the Miller 250. I have a 10lb roll of .030 and don't have a liner but for the .035. What if any problems will I have if I use this smallroll before buying another .035 roll?
You can run .030" in a .035" liner all right. I run .023" all the way up to .045" in both of my machines thru a liner that's good for .052".
Also, when I run any kind of alloy wire, I always run the next size up contact tip so the wire doesn't bind in the tip.
