CK5 Network
Repairing, restoring or modifying your ride just got a whole lot easier!
01 8.1 burb.
Wes Harden
3/4 ton status
Premium Member
Solutions
Lake Havasu City AZ
finial cooling system fill 6.5 gl. Rear pads replaced, they were paper thin. Just a few miles from metal to metal. Left to do, bleed brakes including the abs module. Trans and diff service yet to be done.
Wes Harden
3/4 ton status
Premium Member
Solutions
Lake Havasu City AZ
Yesterday, got it all back together.
Cleaned and waxed wheels, ordered some Goodyear Wrangler at adventure tires. Discount Tire is installing now.
Power steering and hydraulic booster bleed no issues. After road test just @ 1oz to top off p/s reservoir.
Coolant fill bottle was 1/2 over full, at full cold line this morning.
1st trip towing will be tomorrow or Friday. Heading to CA to finish the motor home repairs I started in late June. Needs to be done for our trip to Mammoth mountain, the one that is same time as BB22.
Will be towing the dune buggy to CA, not heavy don't expect any issues. Biggest problem should be my heavy foot.
Wes Harden
3/4 ton status
Premium Member
Solutions
Lake Havasu City AZ
After tires were done, got in truck and and brake warning light on wtf.
Not wanting to be AH customer I left. Got home shut off, restart no lights.
The tires are much quieter than the Pirelli that were on there. Almost had me thinking a bad hub bearing in front. All better now.
Later I went out torqued the wheels again. Torques were all over the place. Air pressure adjustment. 58psi in rear and 45psi in front atm. I took the caps off so they would crack all the plastic caps.
Ordered a TopDon AD600S scan tool so I could do abs bleed. Checked codes no present ,C0265 in history. Find my way to the correct spot to do abs module bleed, It won't do it says has codes. Back out of that module, go to read code module no codes wtf? Check history same C0265.
Clear codes, check codes, now have a current C0265. So look that up GM service bulletin says
bad grounds at frame near ABS module. Find and clean ground. Was oily from hydraulic booster leak.
Clear codes, find my way back to abs bleed function, do the abs service successfully.
Very clunky user interface, and switching between module functions, the scanner has to relearn vehicle specs every time. Slows going.
I suppose it's ok for casual use, would not want to be a flat rate tech and have to use this. For just at $200. I guess is ok.
Wes Harden
3/4 ton status
Premium Member
Solutions
Lake Havasu City AZ
Little stuff today and clean put stuff away.
Oil filler cap was loose allowing unfiltered air into crank case.
New cap solved that.
Tested trailer plug no right turn sig. This truck has separate fuse for ea trailer turn light, was good.
Go to the pig tail. PO mess.
Redid all the splices, and wa la right turn works at plug.
Pictures, not as bad as most but not good enough.
Wes Harden
3/4 ton status
Premium Member
Solutions
Lake Havasu City AZ
Well 1st road trip. Burb cruised across I40 at 103 to 107 outside temps. Trans got to 200 by factory gauge. Water temp stayed rock solid at 205.
1 hill near the top went from 3rd to 2nd, 4k rpm at 63mph. 2400 rpm at 63 in 3rd, 1950 rpm 63mph 4th. Tow haul on.
Ready to leave got to find another ball mount.
Wes Harden
3/4 ton status
Premium Member
Solutions
Lake Havasu City AZ
Not the project I had in mind today, but one that was on list.
Service the rear diff. I thought maybe had never been done.
Evidence of over rtv use tells me it has.
Got a nice lube locker gasket for her.
Question to friction modify or not to friction modify.
When I first checked Rpo codes G80 in 14bff doesnt use.
Look at 3rd member looks like friction disc.
What says the tribe.
centexk5
Premium Member
Georgetown, TX
Depends on the fluid. Amsoil doesn’t require it. I should preface that with the govloc it didn’t need it. Need to check with the Detroit.
Russell
3/4 ton status
Premium Member
Rocky View County, AB
That doesn't look like a stock carrier to me. Not sure what kind of locker it is, but I'd try to find out to make sure it gets the right fluid.
Wes Harden
3/4 ton status
Premium Member
Solutions
Lake Havasu City AZ
I am suspicious. No numbers at all on ring gear, nada nothing.
Only numbers on carrier pictured below. It act like a 1 legger turning one tire forward the other goes reverse.
11 pinion and 41 ring 3.72.
