Sold 10 bolt Auburn 30 spline
Babaganoosh
1 ton status
Phoenix Arizona
Bought this off of frankin5 out of his K5, I never used it but the part is still used. Still in the same box he shipped it to me in. Would like to get what I paid for it $100 shipped. Here is the picture he used for the ad, I can get more if requested.
Is this an OEM posi? also don't think there is a carrier break for these? Or 3.08 down or something. Need SOMETHING for my Yukon, I get stuck on wet grass n level ground....
Honestly I'm not even sure, @frankin5 had them on his 4.56 gears which is what I have.
This would be a temp thing, don't wanna put too much into since Im doing an SAS soon. But with no 4wd working and a 1 wheel peel, it sucks. Plus would be a good selling point when I go to sell it. I'll do some checking on it. Is there a part number on it?
I know it would fit mine with the 30 splines, and thinking carrier break is 2.73 and up, so even if wanted to run stock 3.73s, it should work.
Carrier break is 2.73 and up to 5.38 @Babaganoosh @b454rat
Note it does not fit the 8.6 housing, even through they use the same ring and pinion. An 8.6 carrier can be used in the 8.5 housing with trick bearing.
8.6 is the 99-up trucks, I have a 96, IF has the original axles, but even if not it should still work. Rear isn't disc...
