andyblack
Registered Loser
I've got a problem and I'm posting here becuase I need to get this resolved ASAP and this section of the forum sees the most traffic.
I had two of the studs break that hold the steering arm onto the driver's side steering knuckle on the 10 bolt front axle on my '85 pickup. I thought I had the problem solved when I found a knuckle off of an '86 Blazer and put it on the axle, only to find that the new knuckle had the hole for the tie rod reamed to accept the tie rod from the top, and my tie rod goes in from the bottom. So I had to take it off. Now I can't find a replacement knuckle. The even bigger problem is, the truck is broke down on the air force base where I work. It's been there in a parking lot on a jack stand for over a week and the security forces (Air Force MPs) are starting to leave ugly notes and stuff on it. I can't move it without a knuckle because it won't steer.
Where can I find a steering knuckle ASAP? Someone please help!!
