DavidB
Truck : Uncle Sam's '01 2500 HD gas engine 4x4 Xcab Shortbed. Metal uh, camper shell in bed.
Overload leaf removed for travel. Hyd bumpstops added along with airbags inboard of frame/leaves. Bags and bumps look dead. Limit straps - OK. ORD shackle flip, zero rate, stock leaves sagged a bit.
14FF center section is rotated up about 5-6" at the pinion, maybe 35*. Plug welds are mostly spit out. No traction bar. Driveshaft gone.
Current theory is the constant vertical beating loosens the tubes' press fit in the center section and weakens the plug welds. The airbags putting pressure on the axle so far inboard increses their leverage and probably doesn't help. Trucks get used in sand all the time and they have 25 PSI Off Road on the fender. I suspect they're getting axle wrap/chatter which shock loads the center section and it rotates up.
Anyone got any more ideas? Think we can rotate the housing back down, preload it, weld it, and call it good?
) but I would think the dissimilar metals just won't hold a weld well, and the plug welds are present just to keep the press fit tubes from walking out.
