12V Winch to 24V system?
stallion85 said:
thanks Smitty I will PM you if I have any questions. I found the wirte up and found it pretty easy to understand, but I might have a few questions:)
I did find one minor thing that would have made it easier if you are following the directions. They have you add a ground wire to the right alternator. Later they have you remove a capacitor from the same alternator. Recommend you remove the capacitor while you're adding the ground wire. It will save you from removing the mounting hardware twice. Not a big deal, but I dropped that nut the second time and it took me a while to find it :( .
