1330 to 1350 conversion u-joint
lrazer
Mokena, IL
i need a 1330 to 1350 conversion ujoint. does anyone have any part numbers or suggestions on where to get one?
The Napa PN 447 is a 1330-1350 combo joint used in going from a 10 bolt to a 14 bolt.
The Napa PN 348 is a 1310-1350 combo joint used when going from 12 bolt to 14 bolt.
The 447 is a Saginaw 44 Joint to a 1350. NOT a 1330.
73-87 trucks never came with a 1330, its a S44.
If the original poster really wants a 1330 to 1350 joint its Neapco PN 2-3050.
1310-1350 is Neapco PN - 3-3140
S44-1350 is Neapco PN - 2-1153
i have a 89 blazer that had a 10b in it, the ujoints have inside clips. i was told it was a 1330 to 1350 that i needed to go to a 14b. is this correct or no?
i have already tried a 1310 to 1350 and this is not the correct u-joint
S44 to 14bolt joint is correct one.... i just pulled those p/n's from the part numbers post without thinking about it, sorry
I have a Car-quest u-joint book. It shows a 1330-1350 conversion joint as a p/n 2-3050. If you don't have a Car-quest, NAPA should be able to cross-reference it.
You need a S44 to 1350.
Neapco PN 2-1153
