Wanted 14 bolt FF 4.10 gears
formercruiserhead
Granger Indiana
Looking for 14 Bolt FF 4.10 gears with bearings, carrier etc. Want to unbolt my 3.73 gear set and bolt in 4.10s without having to start from new. (bearings, ring bolts etc) Bought a "set" of front and rear axles and ended up being mismatched.
You are better off finding the right axle.
Cost will be the same and no work is involved.
4.10 is quite common so you can find one easy
