14 Bolt FF Stuck Drum
I've read this a couple times and just want to make sure I understand correctly. You took out the lock nut, the lock ring/washer and the adjusting nut?? Because on a full floater all the bearings/races come out the back. Just want to make sure you didn't miss the inner nut. Heres a cutaway. View attachment 473669
Apologies, I know I dumped a lot of info in this thread and probably used incorrect terminology. All that is left is the inner bearing behind the drum. I can pry the drum, but the damn springs pull it right back where the anchor pin is located. It barely moves if I use a crowbar at the point where the anchor pin is at.
Did you try the big nut and knock the anchor pin out too ? that is holding the return springs. If the hold down pin have been cut as suggested by @kennyw then it should be free to slide off.
Tried the adjuster and that thing is unmovable. Completely rusted solid. put a chisel through the cylinder hole and knocked all 3 springs off the anchor pin. Not sure what's going on but there should not be anything holding the shoes onto the backplate at this point and I still have the same issue. The drum is stuck right at the anchor pin location. I can pry it out slightly, but not enough to get it off. At this point, I'm about ready to get a hub puller for NAPA and try that.
Finally got it!!! Should have stuck with my gut and tried this yesterday! I'd buy you a beer if I could good sir!
drum-brake-jpg.3133159
spline-jpg.3133158
Don't mind my fancy slippers! I was going in and out of the house trying to figure this one out.
