I have a noise coming form my 14 bolt. I have very minor (if any) pinion movement side to side, but I have a pretty good amount of rotational pinion movement. How much rotational pinion movement should be present?
If I need to end-up replacing my pinion bearings, do I have to pull apart the carrier, or can I remove the pinion support and R+R the bearings seals etc. Would hat affect the back lash in any way as long as I keep the pinion hosing shims the same?
Anything helps, thanks.
