Today I talked to a man selling a 14 bolt ff. 200 bucks...cheapest around. A couple of quick questions, he says the measurement between centerpins is aprox 43.5, I'm pretty sure mine is 42.5 (1989 GMC Jimmy). Is that a 42.5 and he might of had trouble measuring it with the pumpkin? Or is there a 43.5 version of the 14 bolt?
I'm sure he probably just had trouble measuring it correctly, there's no 43.5" stock application. Lay something on the ground and measure that way if you're really curious.
And also how hard is it to regear a 14 bolt?
It's probably the easiest axle out there to learn on due to the removable pinion support and the carrier bearing adjusting collars (as opposed to shims). The only real annoyance is the crush sleeve.
http://www.pirate4x4.com/articles/tech/billavista/Gear_Setup
Also what should I be looking for when I go and see it? Thanks for all the feed back in advanced all.
While $200 is a bit higher than I'd like to pay for most 100k+ mile 14 bolts, if you find one in great condition (or if they are just uncommon in your region) than $200 isn't so bad. I would pull the cover and investigate the gears, maybe even bring some Desitin or toothpaste to check the pattern if I were paying that much for it. Feel the pinion bearing/backlash at least, as that's easy to do without taking anything apart. Leaks are an obvious sign of anything, although the cover seal and the shaft flange seals are irrelevant, but the pinion seal (will require a new crush sleeve) and hub seals (may be a sign of torn up spindle/wheel bearings).
