Got a R&P set today (used) and the snub shaft on the pinion shows 2 or 3 little worn grooves around it.
Will this affect anything? The grooves go around the shaft, not perpendicular to it. Is there such a thing as a Speedi-Sleev for them? If so, what is done about the pinion snout bearing since the Sleev would be a little larger in diameter?
Can and will get a pic of the snub later if you want to see. Just checking to see if anyone else experienced this.
