blazin_blazer
in the article, he is using 4'' bs, and the only 15'' 8 lug wheel, i can find is 3.5'' bs...so less grinding i would assume, as would 3'' bs(if i can find em)..and i've been told that 2.75 bs requires no grinding...is this true? if so what would it hurt to run 2.75 bs?
in the article, after he's done he says he only removed about 1/8'' from caliper to back of his 4'' bs rim, it looked like he had to take down outside half of caliper and the ledge he left looks alot deeper than 1/8''....what say ye, ol' bretheran of the round wheels?
does 2.75 bs cause havoc on the d60 bearings or are they beefy enuff to handle it??(44''tsls) a 3.5 bs is still kinda deep on the caliper,....so would 3'' bs be a happy medium?
this is only 8 lug 15'', i can find:
http://www.ntwonline.com/acb/showdetl.cfm?&DID=48&Product_ID=2202&CATID=11
where can i find a good heavy steel wheel w/either 2.75 or 3'' bs or should i use the 3.5 bs?
please post up the knowledge! as i'm ready to order these wheels!
