4BT cummins
A baby 2.8 Cummins haha
Even a Tracker 1.6L would double your HP.
VW 1.9L diesel
company called Subaru Gears will make any adapter, if you wanted to go that way.
4BT cummins
I can't find adapter kits for anything other than GM V8 or SBF.I swapped a 1.6L tracker engine into a Suzuki samurai to replace the 1.3 and I’ll agree it felt like a hot rod
You mean gm.I can't find adapter kits for anything other than GM V8 or SBF.
I would prefer mechanical diesel or carbureted whatever instead of computer control. I like the thoughts of the 5-wire wiring harness.
The small 4s and 60° V6 are different too. I considered a 3.1/3.4 engine with a carb but the bellhousing with mechanical clutch is the hold up on that route.You mean gm.
All gm will bolt to the same bellhousing.
Well except the odd modular in-line engines in the trailblazers
Passenger.What side is/are the diffs on?
Yep.Both diffs?
Yeah that one is tits!1945 Willys MB. Part 5, Actually doing things
TreeFarm submitted a new Build: 1945 Willys MB. Part 4, Its time to get my life together build This is the story of my first 4x4. A 1945 Willys MB SN 428411 born on March 23 1945 Read more about this build here...ck5.com
In case you haven't read thru it.
Hmmmmm. Therein lies the rub.Yep.
That thing is awesome. Gonna read through it more in depth later.1945 Willys MB. Part 5, Actually doing things
Or the 3.84.3 90 degree V6. The made a million, carbing one would be cake...or run the TBI most came with. Plenty of tq to be fun, not enough to instantly break shit.
