Clutch driven LS will eventually wear out. Not if but when. Take care of it and the TrueTrac should go forever.
I didn't know it, but I guess they put the driers on the core support. The only thing that haunts my dreams is the wiring. I'm terrible at it.Omfg, that AC wiring SUCKS.
I had to cross reference 4 schematics, to get mine figured out., And it's only like 10 wires.
I get why dudes that have the money, buy all the new stuff.
Its just way less headache.
I have a 700R4 in my '72 with a small hump. I don't think that the electrical plug on the 4l60E will mess with it. Not sure.
I will tell you that I took the Vintage Air out of my '70 K10 and installed factory. One of my reasons was the fan noise, but I had other complaints. The factory box clears my fat-block with ease. (IMHO) It is sitting in the factory position for 4X4 which puts it back close to the firewall.
I would love to move it as far back as possible, just to get better weight bias.
Still kind of winging everything
I went 12b because I'm sure it will be strong enough for what I am doing and it's way cheaper than building a 9".
I don't believe that the A/C box would make a difference. The 6 cyl. holes should be behind where your motor mount stands are currently. (That's what I see under the hood of my "72) IIRC, that is also the 4x4 location. (what they did for 6cyl,4x4 I don't know, doesn't matter here) But you should be able to use the back set of holes to mock up and look at what works. I believe you will have to drill holes for the trans x-member.Ive never set the engine back with AC but I do like putting the engine back in the 6 cyl holes
