1970 Jimmy rear axle / diff identification
Phildeaux10
Newbie
Louisiana
Having trouble decoding my rear axle. Numbers are clear but I can't i.d. it.
RHS W024 2
That is stamped on the axle just left (passenger side) of the diff when staring at the output side. Very clearly stamped.
TIA
RHS W024 2
TIA
Pictures of said axle?
I'll send you a video if you can help. What else specifically on the axle / diff do you need to see. I thought the code I found was what I needed.
Literally just found this. Looks like the axle may have been swapped at some point. RHS code is from a 72 C101763070840129.png
If you found this on a 72 chevy list doesn't mean it wasn't the same offering in 70.
3.07 ratio was the standard offering in this generation.
My 70 was a 3.07 coil spring suspension.
Sold it recently to a friend
