Ok guys here are the parts I need! Any clue where to get them. If they still make them! I may can fix the box and flap.. But I tried to fix the vacuum switch.... No luck. Thanks again.
OK, I think I see what you have now. That vacuum switch is mounted on top of the control, right? I'm not sure it is available by it self. Try at a Chevy dealer. Other than that, it's buy a whole control.
Yes Sir it does... I tried my local Chevy dealer today. No luck. I think you may be right. Looks like the diverter box is hard to find too. May have to buy both new... as if I'm not broke enough right now. But I have to fix it.. Ya know.
First of all Thank You this is the best site.. I just left that site too. I think I will just order both parts from them. I'm just wondering if the vacuum switch I need will come with that Unit. Mine is a two port...
Ok I'm all done. For the most part. Here's what I replaced all vents, a/c heater control unit diverter box and hooked up all vacuum lines. I know I really didn't need to hook up all the vacuum lines "I'm not running A/C" but I was under the dash so why not. At least the door on the kick panel opens and closes as it should. Any way here's my question. When I switch from A/C to heater the vents stop and the air is diverted to the floor and defrost. Is that correct? When I switch from cold to hot it blows still through the vents... It just gets hotter. Is this right? Inside and de ice I can't really tell what it does other than close the vent doors. I'm about 98.9% sure it's hooked up right. I really took my time. I have never had it working right so I have nothing to compare it to. Does this sound right?
