I was being sarcastic.
Got the shift kit installed in the Chevy TH350 I've had from a C10 part out. Only difficulty was getting the pan off. I told Patrick this is what you call an a$$hole amount of RTV.
Makes me wonder if there's a sealing issue or someone is just over zealous.
I also will straighten the pan as much as possible and push the wholes from the inside to make it as best as possible and usually go for a gasket but if I must, rtv is used in minimal quantities and I just get the pan close enough to get all the gaps closed and leave overnight then tighten the next day.I flip the pan over check for squareness and put the lip on a flat surface and go around with a ball pean hammer and hit the bolt holes from the inside out to flatten them out. I prefer the brush on permatex over RTV. but I have used both, not together of course.
Wow, you have been working on only trucks. The Buford is a full frame car. The doors are still going to open and shut if you have jackstands at the front lift points. I did the trans in my Nova that same way in the driveway and even though that was a unibody the doors never sagged.I've gotta figure out how to get the car up a little higher. Currently I use typical plastic ramps that are about 7" tall. The problem is I can't rollover under the car, I'm stuck in whatever orientation I'm in unless I crawl back out. Plus sometimes things are too close and right in my face, like the exhaust.
I see on Roadkill Garage the put jackstands under the lift points at the front. I know there can be a problem there with not being able to open the doors once the weight is on the stands.
I'm curious if there's a better type of jack stand for this purpose. I know 2 post lifts would raise the car in the same place, but they have those big round pads. Is there a jackstand that has round pads like that? I just feel like the narrow little saddles of the standard jackstand seems sketchy under the lift points, like the could slip off.
It was a lot of fun figuring out how to get the trans in and out from under the car this weekend. Out wasn't as bad because we just slid the trans off the jack onto the floor with a little piece of plywood acting as a ramp. However, we could lift the trans onto the jack under the car. Luckily I have 2 floor jacks. We put one under each lower a-arm and jacked the front as high as they would go. Still had to tip the trans forward to roll it under the car.
Any thoughts/ideas?
Cars you definitely need to lift the rear end as well as the front. Even the 94 1500 I swapped the trans in I lifted the rear. Higher the better front and back. But be safe. I’m to old for this shit too. Man I need a hoist. Buddy just called me today asking me to swap a trans into his S 10 blazer. I might do it? But it will be on the floor with jack stands.Wow, you have been working on only trucks. The Buford is a full frame car. The doors are still going to open and shut if you have jackstands at the front lift points. I did the trans in my Nova that same way in the driveway and even though that was a unibody the doors never sagged.
I had regular jackstands on a chunk of 2x12 up front and then jacked up the rear and set our ramps under the rear tires. Had it off the ground enough to slide the trans out on a chunk of cardboard. Still wasn't high enough for the trans jack, but the one we used was a tank and not real slim. I did have enough room to move around under it though. I was 100 pounds lighter then though!
That is true, I haven't had a car to wrench on since we sold the 71 cuda in 2006. And that was the only other project car we've owned. Everything else has been pickups and Blazers.Wow, you have been working on only trucks.
We did lift the rear of the car, but I just had short 3-ton jack stands. With those stands under the axle tubes, even at full height they didn't lift the rear as high as the front on the ramps. I did notice on Roadkill Garage they were using the taller 6-ton stands.Cars you definitely need to lift the rear end as well as the front.
Yeah, I may be wrong about it. I was searching more for the short versus long tail shaft TH350 and just saw some stuff come up about the 200r4.I would double check the 2004r measurement and the drive shaft length. iirc the 2004r is the same length as a power glide/th350 short tail.
In my 66 Chevelle I removed the power glide put the correct flex plate, installed the 2004r with unmodified Chevelle drive shaft. Only mods move the cross member back, add tv cable.
Had the driveshaft shortened too much. I made 2 marks on the shaft because the first time I marked it I realized the yoke was only partially inserted. Inserted it fully and made a second mark. Then later when I was making the notes on the shaft with my sharpie I scribbled out the second mark. So I had them shorten it based on the yoke barely being inserted.
I had it completely turned around in my head. Should have scratched out the first mark while I was under the car!
