1972 K5 4x4 LS Swap
gmfogle
Newbie
Iowa USA
I would like help with finding a cross member and engine perches for 1972 K5 4x4, original cross member does not work. Lots of options for C10 but nothing for 4x4 except Dirty Dingo which requires brake and fuel lines to be re-routed.
I don't have any experience with these but they do say 67 and up, might give them a call.
I don't have any hands-on experience with this swap, but DIY4X has great products worth checking into. You could also check with Hogback Fab. They are easy to find on Instagram. Not sure it they have what you need though.
After doing my swap I think the time savings with the dirty dingo kit makes up for the little work it takes to re route lines. I have a 71 with a 6.0L/sm465/205 and the dingo kit made the swap significantly easier with the mounting adjustability without sacrificing strength. I even had to remove the oil pan after the swap due to a leak and the crossmember can be removed within 15 minutes while the engine sat in the frame snug. Just my experience
