Just a heads up.
If you have one, which I believe includes the majority of the CUCV axles, it's the one with the smaller pinion support bearing.
Timken has cancelled the production of the pinion support bearing. Talked to a few different places today and unless you can find some old stock on the shelves somewhere, they are gone and will not be produced again.
There is not enough material to bore the housing out to fit the larger bearings. Unless there happens to be something closer that was originally designed for something else...
