After reading thru
@Larry 's post about his rearend swap, I decided that it's time to get rid of my weak 3.08 gears and track down a 14BFF.
I'm actually trying to find a decent 3/4 ton van rearend now. I've never like the fact that the rearend was tucked in the rear fender from the factory... so, that 70" WMS TO WMS will hopefully rid me of that. I'm going to follow
@Larry 's recipe for success by sticking with drums. Gonna troll the local JY/CL for 13" drums and backing plates... but for now anything I can find will get me into a more solid future.
A Buddy of mine just bought a very cheap TIG welder... so, I've got some plans for the upcoming weekends!!! I have collected all the parts to convert my 10 bolt front axle to 3/4 ton. I bought front hubs, rotors, calipers, (from a local friend here in Arlington) and some brake supports from BlackBird Customs... I'll probably rebuild all the essentials (bearings, seals, and U-joints) while I'm at it.
When I was bleeding my power steering, I jacked up the front to get the air out of the system by running the steering wheel back and forth until I was wore out. It worked like a charm. (Thanks
@Larry for your online tutorials). But I discovered another problem... it looks like the front driveline CV joint is dragging on the cross member... is that because (four inch lift) my crossmember is bolted directly up to my frame???
In other words, I have these little @1" spacers that are currently positioned under the cross member. I feel like they should be in between the frame and cross member.
Pardon my rusty exhaust...
