1986 Chevy K30 on 42's
86Cucvbeater
north carolina
I'm going to try this again. The last thread had too much crap in it so this will be straight to the point. This is a running driving truck that you can drive everyday or continue building for offroad use. Starts up first try every time and does not smoke. $4200 or trade for daily driver plus cash.
*86 M1008 1 1/4 ton former military truck
*Only 50,000 miles and No Rust
*6.2 Diesel J-Code motor, good power and mileage
*TH-400 automatic trans with rear seal leak(driveable but should be fixed)
*Less than 5000 miles on rebuilt NP 205 transfer case
*Less than 5000 miles on driveshafts and upgraded 1350 and 1410 Ujoints.
*Less than 3000 miles on hydro assist
*Crossover steering
*New 12v gear reduction starter
*New batteries
*Less than 1000 miles on Driver's side knuckle, tie-rod ends, bearings.
*Dana 60 and 14 Bolt both have 4.56 gears, detroit rear, lincoln locked front
*Front 4340 chromolly axle shaft outters, non taper 35spl inners, Warn premium hubs(one needs warrantying)
*Almost new 42in. TSLs in the front
*More than half tread Ground Hawgs in the rear(wear like iron which is good because the tires spin around most corners)
*Hummer Double Beadlocks with cut down Magnesium Runflats (cut down so you wont puncture a tire against a rock at single digit pressures)
*Needs driver's door and fender if you care about appearance.
*Needs front axle pinion seal
*Batteries have parasitic draw from an unknown source but I haven't looked into it.
The tires all measure 41.5in. tall. Truck is located near Chris Leath Chevrolet in Wake Forest, NC. Test drives welcome.
trade for 1986 monte carlo? good working order 305 chevy 60000 original miles.
surface rust on frame i have repaired a few rust spots could use paint unless u dont care for faded tan paint and a few primer grey spots
What about a 1999 Mercury Cougar in great condition, manual, 90,000 miles no problems, good on gas for a DD, Brand new tires???
